Revisiting the VLAD image representation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Recent works on image retrieval have proposed to index images by compact representations encoding powerful local descriptors, such as the closely related vector of aggregated local descriptors (VLAD) and Fisher vector (FV). By combining them with a suitable coding technique, it is possible to encode an image in a few dozen bytes while achieving excellent retrieval results. This paper revisits some assumptions proposed in this context regarding the handling of ''visual burstiness'', and shows that ad-hoc choices are implicitly done which are not desirable. Focusing on VLAD without loss of generality, we propose to modify several steps of the original design. Albeit simple, these modifications significantly improve VLAD and make it compare favorably against the state of the art.
nextvlad.pdf (295.62 Ko) Télécharger le fichier
Format : Figure, Image
hal-00840653 , version 1 (02-07-2013)
hal-00840653 , version 2 (05-08-2013)
  • HAL Id : hal-00840653 , version 1
Jonathan Delhumeau, Philippe-Henri Gosselin, Hervé Jégou, Patrick Pérez. Revisiting the VLAD image representation. ACM Multimedia, Oct 2013, Barcelona, Spain. ⟨hal-00840653v1⟩
1205 Consultations
4778 Téléchargements
