Semi-Lagrangian simulations of the diocotron instability - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2013
We consider a guiding center simulation on an annulus. We propose here to revisit this test case by using a classical semi-Lagrangian approach. First, we obtain the conservation of the electric energy and mass for some adapted boundary conditions. Then we recall the dispersion relation and discussions on diff erent boundary conditions are detailed. Finally, the semi-Lagrangian code is validated in the linear phase against analytical growth rates given by the dispersion relation. Also we have validated numerically the conservation of electric energy and mass. Numerical issues/diffi culties due to the change of geometry can be tackled in such a test case which thus may be viewed as a fi rst intermediate step between a classical guiding center simulation in a 2D cartesian mesh and a slab 4D drift kinetic simulation.
RRdiocotron_new.pdf (1.12 Mo) Télécharger le fichier
hal-00841504 , version 1 (05-07-2013)
  • HAL Id : hal-00841504 , version 1
Eric Madaule, Sever Adrian Hirstoaga, Michel Mehrenberger, Jérôme Pétri. Semi-Lagrangian simulations of the diocotron instability. [Research Report] 2013. ⟨hal-00841504⟩
541 Consultations
258 Téléchargements
