Semi-classical signal analysis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2010
This study introduces a new signal analysis method called SCSA, based on a semi-classical approach. The main idea in the SCSA is to interpret a pulse-shaped signal as a potential of a Schrödinger operator and then to use the discrete spectrum of this operator for the analysis of the signal. We present some numerical examples and the first results obtained with this method on the analysis of arterial blood pressure waveforms.
LalegEtAl-Semi-Classical_Signal_Analysis.pdf (432.31 Ko) Télécharger le fichier
hal-00844340 , version 1 (05-07-2010)
hal-00844340 , version 2 (15-07-2013)
Taous-Meriem Laleg-Kirati, Emmanuelle Crépeau, Michel Sorine. Semi-classical signal analysis. 2010. ⟨hal-00844340v1⟩
492 Consultations
477 Téléchargements
