Interval state estimation for uncertain nonlinear systems
The objective of this work is to develop some design methods of interval observers for a class of nonlinear continuous-time systems. It is assumed that the estimated system can be represented as a superposition of the nominal subsystem (belonged to the class of uniformly observable systems) and a Lipschitz nonlinear perturbation vanishing at the origin. Then it is shown there exists an interval observer for the system that estimates the set of admissible values for the state consistent with the output measurements. An example of the observer application is given with computer simulation results.
Automatique
