Energy and Throughput Optimization of Wireless Mesh Network with Continuous Power Control - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2013
Providing high data rate with minimum energy consumption is a crucial challenge for next generation wireless networks. This paper focuses on wireless mesh networks using a MAC layer based on S-TDMA (Spatial Time Division Multiple Access). We investigate on the optimization issues combining throughput and energy consumption. Our contributions are two-fold. First, we formulate and solve using column generation a new MILP to compute the energy-throughput tradeoff curve under a physical interference model when the nodes can perform continuous power control and can use a discrete set of data rates. Second, we highlight some network engineering insights. In particular, we show that power control and multi-rate functionalities allow to reach optimal throughput with lower energy consumption using a mix of single hop and multi-hop routes.
RR-TWC.pdf (507.53 Ko) Télécharger le fichier
hal-00844814 , version 1 (16-07-2013)
  • HAL Id : hal-00844814 , version 1
Anis Ouni, Hervé Rivano, Fabrice Valois, Catherine Rosenberg. Energy and Throughput Optimization of Wireless Mesh Network with Continuous Power Control. [Research Report] RR-7730, 2013, pp.27. ⟨hal-00844814⟩
223 Consultations
1046 Téléchargements
