Reconstruction of transparent objects in unstructured scenes with a depth camera - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The visual 3D reconstruction of transparent objects in unstructured scenes is challenging due to the complex image formation principles underlying their visual appearance. Most state-of-the-art reconstruc- tion methods ignore this problem and assume Lambertian reflection. Yet, transparent objects are relevant scene information for applica- tions in intelligent robotics (such as grasping) or virtual reality. In this work, we present an approach to detect non-planar transparent objects, like bottles or glasses, by specifically searching for geom- etry inconsistencies caused by refraction or reflection. Depth infor- mation is acquired using a Kinect sensor, which is moved within the scene in order to acquire multiple views. The individual measure- ments are combined into a 3D volume, yielding the objects' loca- tion and a rough shape estimate. Results are presented using various household objects made of glass or plastic.
2013_icip_alt.pdf (541.27 Ko) Télécharger le fichier
hal-00845456 , version 1 (17-07-2013)
  • HAL Id : hal-00845456 , version 1
Nicolas Alt, Patrick Rives, Eckehard Steinbach. Reconstruction of transparent objects in unstructured scenes with a depth camera. IEEE Int. Conf. on Image Processing, ICIP'13, Sep 2013, Melbourne, Australia. ⟨hal-00845456⟩
401 Consultations
405 Téléchargements
