A robust model-based tracker combining geometrical and color edge information - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper focuses on the issue of estimating the complete 3D pose of the camera with respect to a potentially textureless object, through model-based tracking. We propose to robustly combine complementary geometrical and color edge- based features in the minimization process, and to integrate a multiple-hypotheses framework in the geometrical edge-based registration phase. In order to deal with complex 3D models, our method takes advantage of GPU acceleration. Promising results, outperforming classical state-of-art approaches, have been obtained for space robotics applications on various real and synthetic image sequences and using satellite mock-ups as targets.
iros2013_APetit_vf.pdf (554.66 Ko) Télécharger le fichier
hal-00846683 , version 1 (19-07-2013)
  • HAL Id : hal-00846683 , version 1
Antoine Petit, Eric Marchand, Keyvan Kanani. A robust model-based tracker combining geometrical and color edge information. IEEE/RSJ Int. Conf. on Intelligent Robots and Systems, IROS'2013, Nov 2013, Tokyo, Japan. pp.3719-3724. ⟨hal-00846683⟩
296 Consultations
392 Téléchargements
