Oscillations induced by different timescales in signal modules regulated by slowly evolving protein-protein interactions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IET Systems Biology Année : 2010
The dynamics induced by the existence of different timescales in a system is explored, in the context of a model composed of activation and signalling modules regulated by a slowly evolving process, such as some particular protein-protein interactions or genetic-like dynamics. It is shown that slowly varying regulation patterns can induce rapid changes in the steady states of the (fast varying) signal transduction pathway, and lead to sustained oscillations. These results are illustrated by a reduced model of the Cdc2-cyclin B cell cycle oscillator. Using available experimental data, parameters of the model are estimated and found to agree with the requirements for a mechanism for oscillatory behaviour arising from coupling fast and slow processes.
ndiaye-chaves-gouze-IETsysBio.pdf (859.43 Ko) Télécharger le fichier
ndiaye-chaves-gouze-IETsysBio-supplementary.pdf (173.46 Ko) Télécharger le fichier
hal-00847299 , version 1 (07-08-2013)
Ibrahima Ndiaye, Madalena Chaves, Jean-Luc Gouzé. Oscillations induced by different timescales in signal modules regulated by slowly evolving protein-protein interactions. IET Systems Biology, 2010, 4(4), pp.263-276. ⟨10.1049/iet-syb.2009.0020⟩. ⟨hal-00847299⟩
196 Consultations
174 Téléchargements
