Checkpointing strategies with prediction windows - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper deals with the impact of fault prediction techniques on checkpointing strategies. We consider fault-prediction systems that do not provide exact prediction dates, but instead time intervals during which faults are predicted to strike. These intervals dramatically complicate the analysis of the checkpointing strategies. We propose a new approach based upon two periodic modes, a regular mode outside prediction windows, and a proactive mode inside prediction windows, whenever the size of these windows is large enough. We are able to compute the best period for any size of the prediction windows, thereby deriving the scheduling strategy that minimizes platform waste. In addition, the results of the analytical study are nicely corroborated by a comprehensive set of simulations, which demonstrate the validity of the model and the accuracy of the approach.
main.pdf (269.35 Ko) Télécharger le fichier
hal-00847622 , version 1 (24-07-2013)
  • HAL Id : hal-00847622 , version 1
Guillaume Aupy, Yves Robert, Frédéric Vivien, Dounia Zaidouni. Checkpointing strategies with prediction windows. PRDC - The 19th IEEE Pacific Rim International Symposium on Dependable Computing - 2013, Dec 2013, Vancouver, Canada. ⟨hal-00847622⟩
136 Consultations
107 Téléchargements
