Interaction between Time Scales in Microalgae Based Processes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Microalgae are often seen as a potential biofuel producer. In order to predict achievable productivities in the so called raceway culturing system, the dynamics of photosynthesis has to be taken into account. In particular, the dynamical effect of inhibition by an excess of light (photoinhibition) must be represented. We propose a model considering both photosynthesis and growth dynamics. This model involves three different time scales. We study the response of this model to fluctuating light with different frequencies by slow fast approximations. Therefore, we identify three different regimes for which a simplified expression for the model can be derived. These expressions give a hint on productivity improvement which can be expected by stimulating photosynthesis with a faster hydrodynamics.
Fichier non déposé
hal-00848416 , version 1 (26-07-2013)
Philipp Hartmann, Quentin Béchet, Olivier Bernard. Interaction between Time Scales in Microalgae Based Processes. 20th Mediterranean Conference on Control & Automation (MED), 2012, Barcelona, Spain. pp.561--566, ⟨10.1109/MED.2012.6265697⟩. ⟨hal-00848416⟩
127 Consultations
0 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
