A Process-Oriented Software Architecture Reconstruction Taxonomy - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès CSMR 2007 Année : 2007
To maintain and understand large applications, it is cru- cial to know their architecture. The first problem is that architectures are not explicitly represented in the code as classes and packages are. The second problem is that suc- cessful applications evolve over time so their architecture inevitably drifts. Reconstructing and checking whether the architecture is still valid is thus an important aid. While there is a plethora of approaches and techniques supporting architecture reconstruction, there is no comprehensive state of the art and it is often difficult to compare the ap- proaches. This article presents a first state of the art in soft- ware architecture reconstruction, with the desire to support the understanding of the field.
Poll07a-CSMRSARTaxonomy.pdf (201.05 Ko) Télécharger le fichier
hal-00849009 , version 1 (29-07-2013)
  • HAL Id : hal-00849009 , version 1
Stéphane Ducasse, Damien Pollet, Loic Poyet. A Process-Oriented Software Architecture Reconstruction Taxonomy. CSMR 2007 - 11th European Conference on Software Maintenance and Reengineering, Mar 2007, Amsterdam, Netherlands. ⟨hal-00849009⟩
128 Consultations
163 Téléchargements
