Modelling Organ Deformation Using Mass-Springs and Tensional Integrity - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
In this paper we propose a new framework for deformation modelling based on a combined mass spring and tensional integrity method. The synergy between balanced tension and compression components offered by the tensegrity model helps the deforming organ retain its shape more consistently. We chose the diaphragm as our test object given its heterogeneous composition (muscle and tendon) and its importance in radiotherapy and other interventional procedures. Diaphragm motion can significantly influence surrounding organs such as lungs and liver. Our system permits the control of simulated diaphragm motion and deformation by at least two independent parameters.
isbms08.pdf (1.49 Mo) Télécharger le fichier
Format : Figure, Image
hal-00849197 , version 1 (30-07-2013)
  • HAL Id : hal-00849197 , version 1
Pierre-Frédéric Villard, Wesley Bourne, Fernando Bello. Modelling Organ Deformation Using Mass-Springs and Tensional Integrity. ISBMS, 2008, London, United Kingdom. pp.221-226. ⟨hal-00849197⟩
Collections
TDS-MACS
101 Consultations
195 Téléchargements
