Lung Mesh Generation to Simulate Breathing Motion with a Finite Element Method - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2004
Numerical modelling of lung behaviour during the respiration cycle is a difficult challenge due to its complex geometry and surrounding environment constraints. This paper presents an approach to simulate a patient's lung motion during inhaling and exhaling based on a continuous media mechanics model and solved with a finite element method. One of the key problems is an adequate lung mesh generation, which is specifically developed in this paper.
London04.pdf (1.4 Mo) Télécharger le fichier
Format : Figure, Image
hal-00849206 , version 1 (30-07-2013)
  • HAL Id : hal-00849206 , version 1
Pierre-Frédéric Villard, Michaël Beuve, Behzad Shariat, Vincent Baudet, Fabrice Jaillet. Lung Mesh Generation to Simulate Breathing Motion with a Finite Element Method. Information Visualisation, 2004, London, United Kingdom. pp.194--199. ⟨hal-00849206⟩
298 Consultations
235 Téléchargements
