An Energy Efficient Adaptive HELLO Algorithm for Mobile Ad Hoc Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
HELLO protocol or neighborhood discovery is essential in wireless ad hoc networks. It makes the rules for nodes to claim their existence/aliveness. In the presence of node mobility, no x optimal HELLO frequency and optimal transmission range exist to maintain accurate neighborhood tables while reducing the energy consumption and bandwidth occupation. Thus a Turnover based Frequency and transmission Power Adaptation algorithm (TFPA) is presented in this paper. The method enables nodes in mobile networks to dynamically adjust both their HELLO frequency and transmission range depending on the relative speed. In TFPA, each node monitors its neighborhood table to count new neighbors and calculate the turnover ratio. The relationship between relative speed and turnover ratio is formulated and optimal transmission range is derived according to battery consumption model to minimize the overall transmission energy. By taking advantage of the theoretical analysis, the HELLO frequency is adapted dynamically in conjunction with the transmission range to maintain accurate neighborhood table and to allow important energy savings. The algorithm is simulated and compared to other state-of-the-art algorithms. The experimental results demonstrate that the TFPA algorithm obtains high neighborhood accuracy with low HELLO frequency (at least 11% average reduction) and with the lowest energy consumption. Besides, the TFPA algorithm does not require any additional GPS-like device to estimate the relative speed for each node, hence the hardware cost is reduced.
MSWIM2013v2.pdf (900.2 Ko) Télécharger le fichier
hal-00850350 , version 1 (02-12-2013)
  • HAL Id : hal-00850350 , version 1
Danping He, Nathalie Mitton, David Simplot-Ryl. An Energy Efficient Adaptive HELLO Algorithm for Mobile Ad Hoc Networks. The 16th ACM/IEEE International Conference on Modeling, Analysis and Simulation of Wireless and Mobile Systems (MSWIM), Nov 2013, Barcelona, Spain. ⟨hal-00850350⟩
Collections
INRIA INRIA2
137 Consultations
221 Téléchargements
