The Interaction Picture method for solving the generalized nonlinear Schrödinger equation in optics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2014
The ''interaction picture'' (IP) method is a very promising alternative to Split-Step methods for solving certain type of partial differential equations such as the nonlinear Schrödinger equation involved in the simulation of wave propagation in optical fibers. The method exhibits interesting convergence properties and is likely to provide more accurate numerical results than cost comparable Split-Step methods such as the Symmetric Split-Step method. In this work we investigate in detail the numerical properties of the IP method and carry out a precise comparison between the IP method and the Symmetric Split-Step method.
rk4ip-revised.pdf (469.2 Ko) Télécharger le fichier
hal-00850518 , version 1 (07-08-2013)
hal-00850518 , version 2 (01-04-2014)
hal-00850518 , version 3 (14-09-2015)
hal-00850518 , version 4 (08-06-2016)
  • HAL Id : hal-00850518 , version 2
Stéphane Balac, Arnaud Fernandez, Fabrice Mahé, Florian Méhats, Rozenn Texier-Picard. The Interaction Picture method for solving the generalized nonlinear Schrödinger equation in optics. 2014. ⟨hal-00850518v2⟩
883 Consultations
2332 Téléchargements
