PlantGL: A Python-based geometric library for 3D plant modelling at different scales - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Graphical Models Année : 2009
In this paper, we present PlantGL, an open-source graphic toolkit for the creation, simulation and analysis of 3D virtual plants. This C++ geometric library is embedded in the Python language which makes it a powerful user-interactive platform for plant modeling in various biological application domains. PlantGL makes it possible to build and manipulate geometric models of plants or plant parts, ranging from tissues and organs to plant populations. Based on a scene graph augmented with primitives dedicated to plant representation, several methods are provided to create plant architectures from either field measurements or procedural algorithms. Because they are particularly useful in plant design and analysis, special attention has been paid to the definition and use of branching system envelopes. Several examples from different modelling applications illustrate how PlantGL can be used to construct, analyse or manipulate geometric models at different scales ranging from tissues to plant communities.
plantgl.pdf (2.17 Mo) Télécharger le fichier
Format : Figure, Image
hal-00850782 , version 1 (08-08-2013)
Christophe Pradal, Frédéric Boudon, Christophe Nouguier, Jérôme Chopard, Christophe Godin. PlantGL: A Python-based geometric library for 3D plant modelling at different scales. Graphical Models, 2009, 71 (1), 1--21, posted-at = 2008-11-04 14:10:07. ⟨10.1016/j.gmod.2008.10.001⟩. ⟨hal-00850782⟩
536 Consultations
3635 Téléchargements
