Exploiting model driven technology: a tale of two startups - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Software and Systems Modeling Année : 2012
Tony Clark
  • Fonction : Auteur
  • PersonId : 944543
This article describes the experiences of two independent start-up companies that were created in the white-heat of the early days of model-based engineering. Each company aimed to revolutionise software development by raising the level of abstraction through modelling. The article describes the context, technical innovations, business experiences, demise and lessons learned by each company.
MIPS_2012_13_MANUSCRIT.pdf (1.66 Mo) Télécharger le fichier
hal-00851977 , version 1 (19-08-2013)
Tony Clark, Pierre-Alain Muller. Exploiting model driven technology: a tale of two startups. Software and Systems Modeling, 2012, 11 (4), pp.1134 - 1143. ⟨10.1007/s10270-010-0172-x⟩. ⟨hal-00851977⟩
Collections
SITE-ALSACE IRIMAS
71 Consultations
1733 Téléchargements
