Partial visibility constraint in 3D visual servoing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Olivier Kermorgant
Connectez-vous pour contacter l'auteur
In this paper we address the problem of visibility in position-based visual servoing. It is well known that the observed object may leave the field of view in such schemes, as there is usually no control in the image. Recent control schemes try to cope with this issue by defining an image-based constraint such that the object stays in the image. We propose to increase the convergence domain of such schemes by defining a new constraint that allows the observed object to leave partially the field of view. The general formulation is exposed and the computation of this constraint is detailed. Experiments show that controlling the visibility loss allows performing positionbased visual servoing tasks that were impossible to perform while keeping the whole object in the image.
2013_Kermorgant_PartialVisibility.pdf (756.55 Ko) Télécharger le fichier
hal-00857690 , version 1 (03-09-2013)
hal-00857690 , version 2 (04-09-2013)
  • HAL Id : hal-00857690 , version 2
Olivier Kermorgant. Partial visibility constraint in 3D visual servoing. IEEE/RSJ Int. Conf. on Intelligent Robots and Systems, IROS'13, Nov 2013, Tokyo, Japan. ⟨hal-00857690v2⟩
107 Consultations
262 Téléchargements
