Hemodynamic-informed parcellation of fMRI data in a Joint Detection Estimation framework - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Identifying brain hemodynamics in event-related functional MRI (fMRI) data is a crucial issue to disentangle the vascular response from the neuronal activity in the BOLD signal. This question is usually addressed by estimating the so-called Hemodynamic Response Function (HRF). Voxelwise or region-/parcelwise inference schemes have been proposed to achieve this goal but so far all known contributions commit to pre-specified spatial supports for the hemodynamic territories by defining these supports either as individual voxels or a priori fixed brain parcels. In this paper, we introduce a Joint Parcellation-Detection-Estimation (JPDE) procedure that incorporates an adaptive parcel identification step based upon local hemodynamic properties. Efficient inference of both evoked activity, HRF shapes and supports is then achieved using variational approximations. Validation on synthetic and real fMRI data demonstrate the JPDE performance over standard detection estimation schemes and suggest it as a new brain exploration tool.
MICCAI_CHAARI_final.pdf (506.96 Ko) Télécharger le fichier
Origine Fichiers produits par l'(les) auteur(s)
hal-00859388 , version 1 (07-09-2013)
Lotfi Chaari, Florence Forbes, Thomas Vincent, Philippe Ciuciu. Hemodynamic-informed parcellation of fMRI data in a Joint Detection Estimation framework. MICCAI 2012 - 15th International Conference on Medical Image Computing and Computer-Assisted Intervention, Oct 2012, Nice, France. pp.180-188, ⟨10.1007/978-3-642-33454-2_23⟩. ⟨hal-00859388⟩
1117 Consultations
156 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
