Anatomy Transfer - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ACM Transactions on Graphics Année : 2013
Anatomy Transfer
Characters with precise internal anatomy are important in film and visual effects, as well as in medical applications. We propose the first semi-automatic method for creating anatomical structures, such as bones, muscles, viscera and fat tissues. This is done by transferring a reference anatomical model from an input template to an arbitrary target character, only defined by its boundary representation (skin). The fat distribution of the target character needs to be specified. We can either infer this information from MRI data, or allow the users to express their creative intent through a new editing tool. The rest of our method runs automatically: it first transfers the bones to the target character, while maintaining their structure as much as possible. The bone layer, along with the target skin eroded using the fat thickness information, are then used to define a volume where we map the internal anatomy of the source model using harmonic (Laplacian) deformation. This way, we are able to quickly generate anatomical models for a large range of target characters, while maintaining anatomical constraints.
Mots clés
main.pdf (12.29 Mo) Télécharger le fichier
Anatomy_Transfer.mp4 (18.92 Mo) Télécharger le fichier
Format : Figure, Image
Format : Autre
hal-00862502 , version 1 (16-09-2013)
Ali Hamadi Dicko, Tiantian Liu, Benjamin Gilles, Ladislav Kavan, François Faure, et al.. Anatomy Transfer. ACM Transactions on Graphics, 2013, ACM SIGGRAPH ASIA, 32 (6), pp.Article No. 188. ⟨10.1145/2508363.2508415⟩. ⟨hal-00862502⟩
1827 Consultations
1556 Téléchargements
