Retraction obstruction to time-varying stabilization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Automatica Année : 2013
This paper address the problem of the global stabilization on a total space of a fiber bundle with a compact base space. We prove that, under mild assumptions (existence of a continuous section and forward unicity of solutions), no equilibrium of a continuous system defined on such a state space can be globally asymptotically uniformly stabilized using continuous time-varying feedback.
obstruction_final.pdf (264.86 Ko) Télécharger le fichier
hal-00862934 , version 1 (19-01-2021)
Emmanuel Bernuau, Wilfrid Perruquetti, Emmanuel Moulay. Retraction obstruction to time-varying stabilization. Automatica, 2013, 49 (6), pp.1941-1943. ⟨10.1016/j.automatica.2013.03.012⟩. ⟨hal-00862934⟩
229 Consultations
91 Téléchargements
