Division-Free Binary-to-Decimal Conversion - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2013
This article presents algorithms that convert multiple precision integer or floating-point numbers from radix $2$ to radix $10$ (or to any radix $b > 2$). Those algorithms, based on the ''scaled remainder tree'' technique, use multiplications instead of divisions in their critical part. Both quadratic and subquadratic algorithms are detailed, with proofs of correctness. Experimental results show that our implementation of those algorithms outperforms the GMP library by up to 50\%.
get_str.pdf (191.21 Ko) Télécharger le fichier
hal-00864293 , version 1 (20-09-2013)
hal-00864293 , version 2 (21-01-2014)
  • HAL Id : hal-00864293 , version 1
Cyril Bouvier, Paul Zimmermann. Division-Free Binary-to-Decimal Conversion. 2013. ⟨hal-00864293v1⟩
699 Consultations
3629 Téléchargements
