Solvability analysis and numerical approximation of linearized cardiac electromechanics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2014
This paper is concerned with the mathematical analysis of a coupled elliptic-parabolic system modeling the interaction between the propagation of electric potential and subsequent deformation of the cardiac tissue. The problem consists in a reaction-diffusion system governing the dynamics of ionic quantities, intra and extra-cellular potentials, and the linearized elasticity equations are adopted to describe the motion of an incompressible material. The coupling between muscle contraction, biochemical reactions and electric activity is introduced with a so-called active strain decomposition framework, where the material gradient of deformation is split into an active (electrophysiology-dependent) part and an elastic (passive) one. Under the assumption of linearized elastic behavior and a truncation of the updated nonlinear diffusivities, we prove existence of weak solutions to the underlying coupled reaction-diffusion system and uniqueness of regular solutions. The proof of existence is based on a combination of parabolic regularization, the Faedo-Galerkin method, and the monotonicity-compactness method of J.L. Lions. A finite element formulation is also introduced, for which we establish existence of discrete solutions and show convergence to a weak solution of the original problem. We close with a numerical example illustrating the convergence of the method and some features of the model.
ABQR.pdf (698.25 Ko) Télécharger le fichier
hal-00865585 , version 1 (24-09-2013)
hal-00865585 , version 2 (16-09-2014)
hal-00865585 , version 3 (29-09-2015)
  • HAL Id : hal-00865585 , version 1
Boris Andreianov, Mostafa Bendahmane, Alfio Quarteroni, Ricardo Ruiz Baier. Solvability analysis and numerical approximation of linearized cardiac electromechanics. 2014. ⟨hal-00865585v1⟩
821 Consultations
412 Téléchargements
