A nonlinear controller for pneumatic servo systems: Design and experimental tests - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE/ASME Transactions on Mechatronics Année : 2013
This paper is dedicated to the problem of pneumatic cylinder control without pressure measurement. Based on the theory of homogeneous, finite time stable, ordinary differential equations, a state feedback nonlinear controller is proposed. The closed loop system stability is proved and an attraction domain of the controller is given. The performances and the effectiveness of the proposed controller are illustrated against an experimental setup consisting of a pneumatic cylinder controlled by dSPACE dS1103 microcontroller.
Automatique
IEEE_SR_MG.pdf (887.26 Ko) Télécharger le fichier
hal-00867054 , version 1 (27-09-2013)
Samer Riachy, Malek Ghanes. A nonlinear controller for pneumatic servo systems: Design and experimental tests. IEEE/ASME Transactions on Mechatronics, 2013, ⟨10.1109/TMECH.2013.2280956⟩. ⟨hal-00867054⟩
267 Consultations
806 Téléchargements
