Efficiently Deciding Mu-calculus with Converse over Finite Trees - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2014
We present a sound and complete satisfiability-testing algorithm and its effective implementation for an alternation-free modal $\mu$-calculus with converse, where formulas are cycle-free, and which is interpreted over finite ordered trees. The time complexity of the satisfiability-testing algorithm is $2^{\mathcal{O}(n)}$ in terms of formula size $n$. The algorithm is implemented using symbolic techniques (BDD). We present crucial implementation techniques and heuristics that we used to make the algorithm as fast as possible in practice. Our implementation is available online, and can be used to solve logical formulas of practically significant size.
Web
tree-calculus.pdf (912.6 Ko) Télécharger le fichier
hal-00868722 , version 1 (01-10-2013)
hal-00868722 , version 2 (31-01-2014)
hal-00868722 , version 3 (03-06-2014)
hal-00868722 , version 4 (14-01-2015)
hal-00868722 , version 5 (30-01-2015)
  • HAL Id : hal-00868722 , version 2
Pierre Genevès, Nabil Layaïda, Alan Schmitt. Efficiently Deciding Mu-calculus with Converse over Finite Trees. 2014. ⟨hal-00868722v2⟩
744 Consultations
648 Téléchargements
