Extracting UML/OCL Integrity Constraints and Derived Types from Relational Databases
Relational databases usually enforce relevant organizational business rules. This aspect is ignored by current database reverse engineering approaches which only focus on the extraction of the structural part of the conceptual schema. Other database elements like triggers, views, column constraints, etc. are not considered by those methods. As a result, the generated conceptual schema is incomplete since integrity constraints and derivation rules enforced by the database are not represented.
Génie logiciel [cs.SE]
