Extracting UML/OCL Integrity Constraints and Derived Types from Relational Databases - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Relational databases usually enforce relevant organizational business rules. This aspect is ignored by current database reverse engineering approaches which only focus on the extraction of the structural part of the conceptual schema. Other database elements like triggers, views, column constraints, etc. are not considered by those methods. As a result, the generated conceptual schema is incomplete since integrity constraints and derivation rules enforced by the database are not represented.
paper_cameraready.pdf (397.62 Ko) Télécharger le fichier
hal-00869231 , version 1 (02-10-2013)
  • HAL Id : hal-00869231 , version 1
Valerio Cosentino, Salvador Martínez. Extracting UML/OCL Integrity Constraints and Derived Types from Relational Databases. 13th International Workshop on OCL, Model Constraint and Query Languages, Sep 2013, Miami, United States. ⟨hal-00869231⟩
439 Consultations
402 Téléchargements
