An algorithmic Survey of Parametric Value Function Approximation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Neural Networks and Learning Systems Année : 2013
Reinforcement learning is a machine learning answer to the optimal control problem. It consists in learning an optimal control policy through interactions with the system to be controlled, the quality of this policy being quantified by the so-called value function. A recurrent subtopic of reinforcement learning is to compute an approximation of this value function when the system is too large for an exact representation. This survey reviews state-of-the-art methods for (parametric) value function approximation by grouping them into three main categories: bootstrapping, residual and projected fixed-point approaches. Related algorithms are derived by considering one of the associated cost functions and a specific minimization method, generally a stochastic gradient descent or a recursive least-squares approach.
vfa_survey.pdf (540.07 Ko) Télécharger le fichier
hal-00869725 , version 1 (06-11-2017)
Matthieu Geist, Olivier Pietquin. An algorithmic Survey of Parametric Value Function Approximation. IEEE Transactions on Neural Networks and Learning Systems, 2013, 24 (6), pp.845-867. ⟨10.1109/TNNLS.2013.2247418⟩. ⟨hal-00869725⟩
Collections
SUPELEC
117 Consultations
527 Téléchargements
