Spatial location priors for Gaussian model based reverberant audio source separation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue EURASIP Journal on Advances in Signal Processing Année : 2013
We consider the Gaussian framework for reverberant audio source separation, where the sources are modeled in the time-frequency domain by their short-term power spectra and their spatial covariance matrices. We propose two alternative probabilistic priors over the spatial covariance matrices which are consistent with the theory of statistical room acoustics and we derive expectation-maximization algorithms for maximum a posteriori (MAP) estimation. We argue that these algorithms provide a statistically principled solution to the permutation problem and to the risk of overfitting resulting from conventional maximum likelihood (ML) estimation. We show experimentally that in a semi-informed scenario where the source positions and certain room characteristics are known, the MAP algorithms outperform their ML counterparts. This opens the way to rigorous statistical treatment of this family of models in other scenarios in the future.
1687-6180-2013-149.pdf (479.71 Ko) Télécharger le fichier
1687-6180-2013-149.xml (176.88 Ko) Télécharger le fichier
Format : Autre
hal-00870191 , version 1 (06-10-2013)
Ngoc Duong, Emmanuel Vincent, Rémi Gribonval. Spatial location priors for Gaussian model based reverberant audio source separation. EURASIP Journal on Advances in Signal Processing, 2013, 2013 (1), pp.149. ⟨10.1186/1687-6180-2013-149⟩. ⟨hal-00870191⟩
405 Consultations
361 Téléchargements
