Prediction of Parallel Speed-ups for Las Vegas Algorithms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We propose a probabilistic model for the parallel execution of Las Vegas algorithms, i.e. randomized algorithms whose runtime might vary from one execution to another, even with the same input. This model aims at predicting the parallel performances (i.e. speedups) by analysis the runtime distribution of the sequential runs of the algorithm. Then, we study in practice the case of a particular Las Vegas algorithm for combinatorial optimization on three classical problems, and compare the model with an actual parallel implementation up to 256 cores. We show that the prediction can be accurate, matching the actual speedups very well up to 100 parallel cores and then with a deviation of about 20% up to 256 cores.
prediction.pdf (757.59 Ko) Télécharger le fichier
Origine Fichiers produits par l'(les) auteur(s)
hal-00870979 , version 1 (08-10-2013)
Charlotte Truchet, Florian Richoux, Philippe Codognet. Prediction of Parallel Speed-ups for Las Vegas Algorithms. 42nd International Conference on Parallel Processing, 2013, Lyon, France. pp.160-169, ⟨10.1109/ICPP.2013.25⟩. ⟨hal-00870979⟩
211 Consultations
220 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
