Three Generalizations of the FOCUS Constraint - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The FOCUS constraint expresses the notion that solutions are concentrated. In practice, this constraint suffers from the rigidity of its semantics. To tackle this issue, we propose three generalizations of the FOCUS constraint. We provide for each one a complete filtering algorithm as well as discussing decompositions.
IJCAI_2013_FOCUS.pdf (530.46 Ko) Télécharger le fichier
Origine Fichiers produits par l'(les) auteur(s)
hal-00871750 , version 1 (15-10-2013)
  • HAL Id : hal-00871750 , version 1
Nina Narodytska, Thierry Petit, Mohamed Siala, Toby Walsh. Three Generalizations of the FOCUS Constraint. 23rd International Joint Conference on Artificial Intelligence (IJCAI 2013), Aug 2013, Beijing, China. p.630 ; ISBN 978-1-57735-633-2. ⟨hal-00871750⟩
717 Consultations
313 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
