Service-Oriented Middleware for Large-Scale Mobile Participatory Sensing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Pervasive and Mobile Computing Année : 2014
Sara Hachem
  • Fonction : Auteur
  • PersonId : 900044
Animesh Pathak
Valérie Issarny
  • Fonction : Auteur
  • PersonId : 833417
In this paper, we introduce MobIoT, a service-oriented middleware that enables large-scale mobile participatory sensing. Scalability is achieved by limiting the participation of redundant sensing devices. Precisely, MobIoT allows a new device to register its services only if it increases the sensing coverage of a physical attribute, along its expected path, for the set of registered devices. We present the design and implementation of MobIoT, which mobile devices use to determine their registration decision and become accessible for their services. Through experiments performed on real datasets, we show that our solution scales, while meeting sensing coverage requirements.
main.pdf (955.66 Ko) Télécharger le fichier
hal-00872407 , version 1 (12-10-2013)
Sara Hachem, Animesh Pathak, Valérie Issarny. Service-Oriented Middleware for Large-Scale Mobile Participatory Sensing. Pervasive and Mobile Computing, 2014, 10, pp.66-82. ⟨10.1016/j.pmcj.2013.10.010⟩. ⟨hal-00872407⟩
244 Consultations
651 Téléchargements
