Stable hyper-pooling and query expansion for event detection - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper makes two complementary contributions to event retrieval in large collections of videos. First, we propose hyper-pooling strategies that encode the frame descriptors into a representation of the video sequence in a stable manner. Our best choices compare favorably with regular pooling techniques based on k-means quantization. Second, we introduce a technique to improve the ranking. It can be interpreted either as a query expansion method or as a similarity adaptation based on the local context of the query video descriptor. Experiments on public benchmarks show that our methods are complementary and improve event retrieval results, without sacrificing efficiency.
douze_iccv13.pdf (3.37 Mo) Télécharger le fichier
Format : Figure, Image
hal-00872751 , version 1 (14-10-2013)
Matthijs Douze, Jérôme Revaud, Cordelia Schmid, Hervé Jégou. Stable hyper-pooling and query expansion for event detection. ICCV 2013 - IEEE International Conference on Computer Vision, Dec 2013, Sydney, Australia. pp.1825-1832, ⟨10.1109/ICCV.2013.229⟩. ⟨hal-00872751⟩
974 Consultations
860 Téléchargements
