Modeling the piano. Numerical Aspects. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper deals with the discretization of our global piano model. We have to solve a complex system of coupled equations, where each subsystem has different spatial dimensions, which poses specific difficulties. The hammer-strings part is a 1D system governed by nonlinear equations. The soundboard is a 2D system with diagonal damping. The acoustic field is a 3D problem in an unbounded domain. Energy based methods allow to build an accurate and a priori stable scheme.
piano.pdf (99.52 Ko) Télécharger le fichier
hal-00873629 , version 1 (16-10-2013)
  • HAL Id : hal-00873629 , version 1
Juliette Chabassier, Antoine Chaigne, Marc Duruflé, Patrick Joly. Modeling the piano. Numerical Aspects.. WAVES 13 : 11th International Conference on Mathematical and Numerical Aspects of Waves, Jun 2013, Tunis, Tunisia. ⟨hal-00873629⟩
259 Consultations
148 Téléchargements
