Modeling the piano. Numerical Aspects.
This paper deals with the discretization of our global piano model. We have to solve a complex system of coupled equations, where each subsystem has different spatial dimensions, which poses specific difficulties. The hammer-strings part is a 1D system governed by nonlinear equations. The soundboard is a 2D system with diagonal damping. The acoustic field is a 3D problem in an unbounded domain. Energy based methods allow to build an accurate and a priori stable scheme.
Domains
Numerical Analysis [cs.NA]
