Continuous tracking of structures from an image sequence - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The talk describes an innovative method to simultaneously estimate motion and track a structure on an image sequence. To process noisy images, assumptions on dynamics should be involved. Consequently, the method relies on the dynamics equations of the studied physical system. Promissing results have been obtained on twin experiments in order to quantify the accuracy of the method. The approach has also been tested on satellite acquisitions in order to track clouds an meteorological satellite acquisitions. Further research will concern the conception of a multi-object tracking method.
GDRE-2013-LEPOITTEVIN-Yann.pdf (99.67 Ko) Télécharger le fichier
hal-00873748 , version 1 (21-10-2013)
  • HAL Id : hal-00873748 , version 1
Yann Lepoittevin, Isabelle Herlin, Dominique Béréziat. Continuous tracking of structures from an image sequence. GDRE ConEDP Meeting 2013 - Modeling and control of systems: applications to nano-sciences, environment and energy, Apr 2013, Grenoble, France. ⟨hal-00873748⟩
171 Consultations
85 Téléchargements
