Error estimates for 1D asymptotic models in coaxial cables with non-homogeneous cross-section - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Advances in Applied Mechanics Année : 2012
This paper is the first contribution towards the rigorous justification of asymptotic 1D models for the time-domain simulation of the propagation of elec- tromagnetic waves in coaxial cables. Our general objective is to derive error esti- mates between the "exact" solution of the full 3D model and the "approximate" solution of the 1D model known as the Telegraphist's equation.
coax_estim_short.pdf (451.27 Ko) Télécharger le fichier
hal-00875808 , version 1 (22-10-2013)
hal-00875808 , version 2 (21-11-2018)
Sébastien Imperiale, Patrick Joly. Error estimates for 1D asymptotic models in coaxial cables with non-homogeneous cross-section. Advances in Applied Mechanics, 2012, ⟨10.4208/aamm.12-12S06⟩. ⟨hal-00875808v1⟩
432 Consultations
295 Téléchargements
