Memorability of natural scenes: the role of attention - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The image memorability consists in the faculty of an image to be recalled after a period of time. Recently, the memorability of an image database was measured and some factors responsible for this memorability were highlighted. In this paper, we investigate the role of visual attention in image memorability around two axis. The first one is experimental and uses results of eye-tracking performed on a set of images of different memorability scores. The second investigation axis is predictive and we show that attention-related features can advantageously replace low-level features in image memorability prediction. From our work it appears that the role of visual attention is important and should be more taken into account along with other low-level features.
Mancas_ICIP_2013.pdf (809.33 Ko) Télécharger le fichier
hal-00876173 , version 1 (23-10-2013)
  • HAL Id : hal-00876173 , version 1
Matei Mancas, Olivier Le Meur. Memorability of natural scenes: the role of attention. ICIP, Sep 2013, Sydney, Australia. ⟨hal-00876173⟩
234 Consultations
527 Téléchargements
