PiMM: Parameterized and Interfaced Dataflow Meta-Model for MPSoCs Runtime Reconfiguration - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Dataflow models of computation are widely used for the specification, analysis, and optimization of Digital Signal Processing (DSP) applications. In this paper a new meta-model called PiMM is introduced to address the important challenge of managing dynamics in DSP-oriented representations. PiMM extends a dataflow model by introducing an explicit parameter dependency tree and an interface-based hierarchical compositionality mechanism. PiMM favors the design of highly efficient heterogeneous multicore systems, specifying algorithms with customizable trade-offs among predictability and exploitation of both static and adaptive task, data and pipeline parallelism. PiMM fosters design space exploration and reconfigurable resource allocation in a flexible dynamic dataflow context.
2013-IC-06.pdf (833.16 Ko) Télécharger le fichier
hal-00877492 , version 1 (28-10-2013)
hal-00877492 , version 2 (16-10-2014)
  • HAL Id : hal-00877492 , version 1
Karol Desnos, Maxime Pelcat, Jean François Nezan, Shuvra S. Bhattacharyya, Slaheddine Aridhi. PiMM: Parameterized and Interfaced Dataflow Meta-Model for MPSoCs Runtime Reconfiguration. 13th International Conference on Embedded Computer Systems: Architecture, Modeling and Simulation (SAMOS XIII), Jul 2013, Samos, Greece. pp.41-48. ⟨hal-00877492v1⟩
614 Consultations
306 Téléchargements
