Double interference fluorescence enhancement from reflective slides: Application to bicolor microarrays - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Applied Physics Letters Année : 2005
Houtai Choumane
  • Fonction : Auteur
  • PersonId : 947693
Khoi-Nguyen Ha
  • Fonction : Auteur
Constantin Nelep
  • Fonction : Auteur
Alain Chardon
  • Fonction : Auteur
Georges-Olivier Reymond
  • Fonction : Auteur
Carole Goutel
  • Fonction : Auteur
Gordana Cerovic
  • Fonction : Auteur
François Vallet
  • Fonction : Auteur
Claude Weisbuch
  • Fonction : Auteur
A technique for enhancing fluorescence from species close to a substrate is described, based on a multilayer dielectric mirror coating. For proper design, interferences bring improvements to both fluorescence excitation and collection, each about four fold. The overall improvement reaches 10 to 15 fold as compared to a standard glass slide. We apply this to so-called deoxyribonucleic acid (DNA) chips, that is to DNA hybridization assays on microarray platforms, for which two fluorophores most commonly used are cyanine dyes (Cy3™ and Cy5™). Impact of the two-color scheme is discussed. A validation method based on spin-coated fluorescent ultrathin layers is shown to accurately determine the amplification factors of the different tagging dyes.
18B_00032.pdf (122.22 Ko) Télécharger le fichier
hal-00879036 , version 1 (31-10-2013)
Houtai Choumane, Khoi-Nguyen Ha, Constantin Nelep, Alain Chardon, Georges-Olivier Reymond, et al.. Double interference fluorescence enhancement from reflective slides: Application to bicolor microarrays. Applied Physics Letters, 2005, 87, pp.031102. ⟨10.1063/1.1999018⟩. ⟨hal-00879036⟩
218 Consultations
395 Téléchargements
