Bounds on the dimension of trivariate spline spaces: A homological approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2013
We consider the vector space of globally differentiable piecewise polynomial functions defined on a three-dimensional polyhedral domain partitioned into tetrahedra. We prove new lower and upper bounds on the dimension of this space by applying homological techniques. We give an insight of different ways of approaching this problem by exploring its connections with the Hilbert series of ideals generated by powers of linear forms, fat points, the so-called Fröberg--Iarrobino conjecture, and the weak Lefschetz property.
splines3d.pdf (242.84 Ko) Télécharger le fichier
hal-00879100 , version 1 (31-10-2013)
hal-00879100 , version 2 (26-02-2014)
  • HAL Id : hal-00879100 , version 1
Bernard Mourrain, Nelly Villamizar. Bounds on the dimension of trivariate spline spaces: A homological approach. 2013. ⟨hal-00879100v1⟩
212 Consultations
193 Téléchargements
