Collaborative Knowledge Acquisition under Control of a Non-Regression Test System - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Gérôme Canals
  • Fonction : Auteur
  • PersonId : 830484
Laura Infante-Blanco
Emmanuel Nauer
This paper introduces BeGoood, a generic system for man- aging non-regression tests on knowledge-bases. BeGoood is a system al- lowing to define test plans in order to monitor the evolution of knowledge- bases. Any system answering queries by providing results in the form of set of strings can be tested with BeGoood. BeGoood has been devel- oped following a REST architecture and is independent of any applica- tion domain. This paper describes the architecture of the system and gives a use case to illustrate how BeGoood is able to manage a collab- orative knowledge evolution in the framework of a case-based reasoning system.
Web
swcs20130_submission_3.pdf (1019.8 Ko) Télécharger le fichier
hal-00880347 , version 1 (05-11-2013)
  • HAL Id : hal-00880347 , version 1
Gérôme Canals, Amélie Cordier, Emmanuel Desmontils, Laura Infante-Blanco, Emmanuel Nauer. Collaborative Knowledge Acquisition under Control of a Non-Regression Test System. Workshop on Semantic Web Collaborative Spaces, May 2013, Montpellier, France. ⟨hal-00880347⟩
823 Consultations
438 Téléchargements
