Collaborative Knowledge Acquisition under Control of a Non-Regression Test System
This paper introduces BeGoood, a generic system for man- aging non-regression tests on knowledge-bases. BeGoood is a system al- lowing to define test plans in order to monitor the evolution of knowledge- bases. Any system answering queries by providing results in the form of set of strings can be tested with BeGoood. BeGoood has been devel- oped following a REST architecture and is independent of any applica- tion domain. This paper describes the architecture of the system and gives a use case to illustrate how BeGoood is able to manage a collab- orative knowledge evolution in the framework of a case-based reasoning system.
Domains
Web
