A reconstruction of Joncourt's table of triangular numbers (1762)
This is an analysis and reconstruction of Joncourt's table of triangular numbers, one of only very few such tables, which was an alternative to other methods for the computation of squares, the extraction of square roots, and even the multiplication.
