Implementing and reasoning about hash-consed data structures in Coq - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2013
We report on four different approaches to implementing hash-consing in Coq programs. The use cases include execution inside Coq, or execution of the extracted OCaml code. We explore the different trade-offs between faithful use of pristine extracted code, and code that is fine-tuned to make use of OCaml programming constructs not available in Coq. We discuss the possible consequences in terms of performances and guarantees. We use the running example of binary decision diagrams and then demonstrate the generality of our solutions by applying them to other examples of hash-consed data structures.
main.pdf (386.03 Ko) Télécharger le fichier
hal-00881085 , version 1 (07-11-2013)
hal-00881085 , version 2 (07-03-2014)
hal-00881085 , version 3 (13-12-2014)
hal-00881085 , version 4 (25-09-2015)
Thomas Braibant, Jacques-Henri Jourdan, David Monniaux. Implementing and reasoning about hash-consed data structures in Coq. 2013. ⟨hal-00881085v1⟩
906 Consultations
833 Téléchargements
