Convergence and performance of the peeling wavelet denoising algorithm - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Metrika Année : 2014
This note is devoted to an analysis of the so-called peeling algorithm in wavelet denoising. Assuming that the wavelet coefficients of the useful signal are modeled by generalized Gaussian random variables and its noisy part by independent Gaussian variables, we compute a critical thresholding constant for the algorithm, which depends on the shape parameter of the generalized Gaussian distribution. We also quantify the optimal number of steps which have to be performed, and analyze the convergence of the algorithm. Several implementations are tested against classical wavelet denoising procedures on benchmark and simulated biological signals.
draft_web.pdf (417.19 Ko) Télécharger le fichier
hal-00903593 , version 1 (12-11-2013)
Céline Lacaux, Aurélie Muller, Radu Ranta, Samy Tindel. Convergence and performance of the peeling wavelet denoising algorithm. Metrika, 2014, 77 (4), pp.509-537. ⟨10.1007/s00184-013-0451-y⟩. ⟨hal-00903593⟩
371 Consultations
176 Téléchargements
