A framework for integrating heterogeneous sporadic knowledge sources into automatic speech recognition - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Heterogeneous knowledge sources that model speech only at certain time frames are difficult to incorporate into speech recognition, given standard multimodal fusion techniques. In this work, we present a new framework for the integration of this sporadic knowledge into standard HMM-based ASR. In a first step, each knowledge source is mapped onto a logarithmic score by using a sigmoid transfer function. Theses scores are then combined with the standard acoustic models by weighted linear combination. Speech recognition experiments with broad phonetic knowledge sources on a broadcast news transcription task show improved recognition results, given knowledge that provides complementary information for the ASR system.
paper-07.pdf (288.57 Ko) Télécharger le fichier
hal-00906348 , version 1 (19-11-2013)
  • HAL Id : hal-00906348 , version 1
Stefan Ziegler, Guillaume Gravier. A framework for integrating heterogeneous sporadic knowledge sources into automatic speech recognition. Workshop on Speech, Language and Audio in Multimedia, 2013, France. pp.37-42. ⟨hal-00906348⟩
127 Consultations
131 Téléchargements
