Reduced Order Models at work - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2013
We review a few applications of reduced-order modeling in aeronautics and medicine. The common idea is to determine an empirical approximation space for a model described by partial differential equations. The empirical approximation space is usually spanned by a small number of global modes. In case of periodic or mainly diffusive phenomena it is shown that this approach can lead to accurate fast simulations of complex problems. In other cases, models based on definition of transport modes significantly improve the accuracy of the reduced model.
manuscript.pdf (1.15 Mo) Télécharger le fichier
Origine Fichiers produits par l'(les) auteur(s)
hal-00906908 , version 1 (20-11-2013)
  • HAL Id : hal-00906908 , version 1
Michel Bergmann, Thierry Colin, Angelo Iollo, Damiano Lombardi, Olivier Saut, et al.. Reduced Order Models at work. Quarteroni, Alfio. Modeling, Simulation and Applications, 9, Springer, 2013. ⟨hal-00906908⟩
551 Consultations
246 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
