Monte Carlo methods for light propagation in biological tissues - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2013
Light propagation in turbid media is driven by the equation of radiative transfer. We give a formal probabilistic representation of its solution in the framework of biological tissues and we implement algorithms based on Monte Carlo methods in order to estimate the quantity of light that is received by an homogeneous tissue when emitted by an optic fiber. A variance reduction method is studied and implemented, as well as a Markov chain Monte Carlo method based on the Metropolis-Hastings algorithm. The resulting estimating methods are then compared to the so-called Wang-Prahl (or Wang) method. Finally, the formal representation allows to derive a non-linear optimization algorithm close to Levenberg-Marquardt that is used for the estimation of the scattering and absorption coefficients of the tissue from measurements.
article.pdf (734.71 Ko) Télécharger le fichier
Origine Fichiers produits par l'(les) auteur(s)
hal-00907391 , version 1 (21-11-2013)
hal-00907391 , version 2 (23-12-2014)
  • HAL Id : hal-00907391 , version 1
Laura Vinckenbosch, Samy Tindel, Magalie Thomassin, Céline Lacaux, Obara Tiphaine. Monte Carlo methods for light propagation in biological tissues. 2013. ⟨hal-00907391v1⟩
336 Consultations
433 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
