A Sufficient Condition for Parameter Identifiability in Robotic Calibration - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2014
Calibration aims at identifying the model parameters of a robot through experimental measures. In this paper, necessary mathematical conditions for calibration are developed, considering the desired accuracy, the sensor inaccuracy of the joint coordinates, and the measurement noise. They enable to define a physically meaningful stop criterion for the identification algorithm and a numerical bound for the observability index O3 , the minimum singular value of the observability matrix. With this bound, observability problems can be safely detected during calibration. Those conditions for calibration are illustrated through a simple example.
Fichier non déposé
hal-00907496 , version 1 (21-11-2013)
Thibault Gayral, David Daney. A Sufficient Condition for Parameter Identifiability in Robotic Calibration. Thomas, Federico and Perez Gracia, Alba. Computational Kinematics, 15, Springer Netherlands, pp.131-138, 2014, Mechanisms and Machine Science, 978-94-007-7213-7. ⟨10.1007/978-94-007-7214-4_15⟩. ⟨hal-00907496⟩
89 Consultations
0 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
